I have a Icinga Agent on Windows Server 2022.
This server just changed it IP-adress.
How can I get Icinga console to use the new IP?
You need to change the ip address of the corresponding host object. If you are using the director, will do this there. Otherwise you need to change the corresponding conf file.
Edit the IP address for that host on your Icinga Master.
If it’s not obvious how to do this, please at least tell us whether you are
using Icinga Director or text configuration files.
Antony.
We did update ip on Icinga Master, and that solved it ![]()
