RadeK.N
(Radek)
November 8, 2020, 4:43pm
1
I am new to Icinga2 monitoring and I try to understand it.
At this moment i monitor network devices by common checks.
I thing good option is install Icinga Agent on important windows workstations or server.
Can you help me step by step what I have to set on icinga 2 server (running ubuntu)
Thanks a lot
Radek
Pooh
(Antony Stone)
November 8, 2020, 5:06pm
2
Have you read and followed
If not, start there, see how you get on, and ask questions here if you get
stuck.
If you have followed those instructions, tell us how far you got and give as
much details about what the problem is.
Regards,
Antony.
Pooh
(Antony Stone)
November 8, 2020, 5:22pm
3
RadeK.N
(Radek)
November 8, 2020, 9:01pm
4
i have only one master, no satelite and at this moment one agent with icinga agent installed, with NSClient++ on Hyper1 server.
icinga2 service on Hyper1 is running. Also with web
So than i add agent to /etc/icinga2/zones.conf
after restarting icinga2 service i get error:
critical/cli: Config validation failed. Re-run with ‘icinga2 daemon -C’ after fixing the conf
after “icinga2 daemon -C” command - it ended with error:
critical/config: Error: Endpoint ‘SPSS-Hyper1.spss-mel.cz’ does not belong to a zone.
stevie-sy
(Stevie Sy)
November 9, 2020, 7:57am
5
Hi
the error message says exactly what is wrong. SPSS-Hyper1.spss-mel.cz is not assigned to a zone!
according your postings your zone should look like this:
object Endpoint "icinga.spss-me1.sz" { }
object Zone "Praque" {
endpoint = [ "icinga.spss-me1.sz" ]
parent = "master"
object Endpoint "SPSS-Hyper1.spss-mel.cz" {
host = "xx.xx.xx"
log_duration = 0
oject Zone "master" {
endpoints = [ "SPSS-Hyper1.spss-mel.cz" ]
RadeK.N
(Radek)
November 9, 2020, 9:16pm
7
hello,
now i have updated right zones.conf:
in hosts.conf i updated :
(using check_command = “nscp”)
seems it is much better - but I cannot find where can I set password in incinga.
On hyper1 i found password in file C:\Program Files\NSClient++\nsclient.ini
But where can i set password in icinga ?
Now i can see this on icinga2 web:
I hope i will understand this somewhen
Radek
stevie-sy
(Stevie Sy)
November 10, 2020, 6:40am
8
nice to read that it is working now.
We don’t use the NSClient. So in this case I can’t help, sorry. We are using the check plugins, which are installed during the installation on Windows, supplemented by the new PowerShell-Framework.
But I’m sure that others from the community have experience with the NSClient.
fluxX
(Alex)
November 10, 2020, 6:48am
9
You need to set the password in the service object with vars.nscp_password = "PASSWORD".
For more infos about available parameters check the nscp docs .
Greetz
RadeK.N
(Radek)
November 15, 2020, 6:18pm
10
So after password I did not receive performance data:
in host.conf i have:
What have i edit / allow / or how correctly run commands ?
Thanks for advice to beginner
