I have a check which need to be run from outside a Client. Because it should check smb shares (check_smb_shares). The Check will fail if it starts from the client.
How can i order this check to this Client but still will be run on the master?
Hi
You can assign the service the
command_endpoint = /location/
and the service will execute the check from the specified location.
See the example here :
apply Service "disk" {
check_command = "disk"
//specify where the check is executed
assign where host.vars.client_endpoint
Thank you for your fast answer.
I tried it but we are working with the director and at the moment it is impossible to set the command_endpoint.
Do you have any other Ideas?
The Director hides the command endpoint settings within the host settings, just mark this host as agent.
How do I do this?
(sry if it is a stupid question)
Here?
