Our backup is running between 22:00 and about 05:00 the next day. I could not figure out how to set this in a scheduled downtime with “apply ScheduledDowntime” in icinga2.
Just setting 22:00-05:00 gives me an error:
Invalid time range definition ‘22:00-05:00’: Time period segment ends before it begins
The current mechanism uses a service variable backup_downtime which in turn triggers the “apply” rule when not empty:
How long will backupdowntime take effect?
I found that it wont take effect immediately, when i set the new backup downtime and reload icinga2.
And i don’t know when it will take effect.
Where can I find the docs about the execution process of backup downtime?
I adjusted the time from “22::00-24:00" to '22:00-29:00’, and reload icinga2.
However, i found this backuptime dont take effect immediately. And, i dont know when it will take effect.What else can I do?
That’s not an accurate check since the cache for object list only is written upon restart or config validation. Downtimes are runtime created objects, and as such, need to be queried via REST APi at /v1/objects/downtimes.
