Please be a little more concrete here - where is the host/service object located, is that inside the satellite zone and checks a remote agent via by_ssh, or something else?
maybe the path is incorrect - if the Host is a RHEL based one, it changes to /usr/lib64/nagios/plugins.
You can check such with running ssh manually with ls -la /usr/lib/nagios/plugins for instance.
You could help yourself with adding specific host templates and import them on the host level.
apply Service "users" {
check_command = "by_ssh"
var plugin_dir = PluginDir // Use a default value
if (host.vars.plugin_dir != "") {
plugin_dir = host.vars.plugin_dir
vars.by_ssh_command = [ plugin_dir + "/check_users" ]
An alternative method would be to specify the distribution_type and match based on this in the service apply rule. I prefer to stash this into the host templates as you do not need to duplicate the string values inside the service apply rules then.
Or you defined the different paths as constants, e.g. RhelPluginDir, DebianPluginDir, SlesPluginDir and use these inside the service apply rule. Depends on your preferred style.
The command which is executed on the remote host needs all binaries to execute, be it monitoring plugins or any other script. If you cannot install anything, you’ll need to find workarounds to execute system commands like ps or df and write a wrapper script on the satellite side then being called instead of check_by_ssh.
