How to multi action_url in icinga2 config to display multi graph data?
Since I have two grafana panels, one is displayed as timeseries data graph and other is displayed as table. I would like to add multi action_url to display both of my panels to thruk web UI.
After search in the doc and github issue I can not find any way to config it ? Is this feature is disable in the config files?
Regards
I guess I don’t get it but a way around it could be if you combine the panels into one?
@rivad Because two panel displayed as two style: timeseries and table. I don’t know how to combine it in grafana and emmbbed it to thruk.
What is thrunk for you?
In my screenshot there is a time series as lines and a table at the bottom.
