Hello, I’m a new comer of icinga2. Here I want to monitor managed OS by their hostnames, not by IP address. I add Ansible block in my “/etc/icinga2/conf.d/custom-cfg” with each segment like below shows. As you can see, there is a parameter “address”. here I need to replace it with a parameter like hostname or something, so I can input variable value by Ansible block. Thanks.
BEGIN ANSIBLE MANAGED BLOCK for Management k8s
object Host “k8s” {
display_name = “k8s”
import “hhq-host”
import “RedHat-ssh-agent”
address = “10.245.77.2”
vars.os = “Linux”
vars.notification[“mail”] = {
/* The UserGroup icingaadmins is defined in users.conf. */
groups = [ “icingaadmins” ] }
