Hi
I am searching how to monitor Linux physical memory on Icinga2 .
I don`t see any plugin for physical memory check and uptime plugin for Linux .
For windows, I am using NSClient++ ,it is fine.
Hi
The plugin isn’t included, but there’s a template for it.
See this here: https://icinga.com/docs/icinga2/latest/doc/10-icinga-template-library/#mem
as well, here’s the link for the plugin itself:
You’ll want to throw that in your default monitoring plugins folder, wherever that is.
I can also suggest Percona’s plugin. Inside their database tool plugin repo there is also a plugin for Nagios/Icinga that checks memory. See here
/George
Hi
Blake
nice to meet you!
I have tested this script.Not working .
Can u tell me how it is working ?
What exactly is not working?
Please describe what you did and what the outcome of running the script is.
To “install” the script:
chmod 755
the script./check_mem.pl --help
to see all command line optionsThe output clearly states that the check_mem.pl
plugin is not found in the /usr/lib64/nagios/plugins
directory.
So either the plugin really does not exist there, or the permissions and/or file ownership settings are wrong.
Running the plugin as root
will always work. What happens if you run it as the user running icinga (typically nagios
on Debian/Ubuntu systems and icinga
on CentOS/RHEL)
This might be an issue with the permissions. Please also share the output of pwd
and ls -l /usr/lib64/nagios/plugins/check_mem.pl
Edit: (basically redundant to what @log1c said. We were posting at the same time. )
CentOS bro
SELinux is enforcing bro .
permission ??
I already given 777 permissions on that check_mem.pl.
CentOS 7.6
SELinux Enforcing .
Edit:
What was the final solution? In case some else stumbles across the problem, they will be happy to find a solution.
