How to install icinga2 client, if client quantities are more than 100?
How to install and configure icinga2 client, if client quantities are more than 100 ?
Nagios can do it.
Thanks !
Hi
Whats makes you think there is a limit of 100 clients? Of course you are better off using some sort of automation for numbers much less than 100. We use ansible for example to roll out clients, and even the director API is super handy for larger scale automation.
