Hi all,
I need to create a list of host that have a “last check” in red (check result is late). is it possible?
there are other methods to identify a satellite that don’t communicate whith master istance?
I would build a filter and then export the CSV.
I use a agent health check - Distributed Monitoring - Icinga 2
Best practice is to have cluster-zone defined for all zones except the master zone.
