I have to check dnf on a linux client from icinga2-Server. In the past I had only to check yum on linux machines. That works fine with check_yum.
But I never found some information or a plugin for check dnf.
not tested by myself but I found this via google: https://github.com/nikkolasg/check_dnf
Thanks @stevie-sy
But we found check_updates. That works fine.
