How do i change my icinga2 web ui, one of my friend has a different icinga ui. We both have the same versions installed everything is same, But his ui shows little more deatails, check the image, i see green strips where as my friend sees a green circle.
Sounds like your friend uses the new IcingaDB and not the classical monitoring module based on the IDO.
Even i have icingadb on mine:
apt-get install icingadb -y
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
icingadb is already the newest version (1.1.1-1+ubuntu22.04).
0 upgraded, 0 newly installed, 0 to remove and 45 not upgraded.
still no changes, how do i get that circle ui
But the screenshot looks still like it’s the classical icingaweb2 monitoring module and not the new icingadb-web module.
i know how do i get the newest module?
you can disable the monitoring module
Disable from the web interface right? I did that and all the options vanished so i again enabled it
update: i installed the icinga db module and now it says:
You seem to not have configured a resource for Icinga DB yet.
you need to configure the icingadb module, “SQL resource”, redis connection and so on.
https://icinga.com/docs/icinga-db-web/latest/doc/03-Configuration/
did that solve your issue?
Hi so i had monitoring module enabled; my issue was fixed by enabling icingadb module.
Thankyou this helped.
