This is a grep on the satellite’s name. i didin’t put all the output but if you want more tell me or if its too much tell me too.
I can refine the search, and I can do it with an other name. (i replaced satellite.FQDN by SATELLITE)
[root@satellite]# cat /var/log/icinga2/debug.log | grep “SATELLITE”
[2019-04-29 08:45:15 +0000] notice/ApiListener: Creating config update for file ‘/etc/icinga2/zones.d/satellite/SATELLITE.conf’.
[2019-04-29 08:45:15 +0000] notice/ApiListener: Creating config update for file ‘/var/lib/icinga2/api/zones/satellite/_etc/SATELLITE.conf’.
[2019-04-29 08:50:45 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:50:55 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:51:02 +0000] information/ApiListener: New client connection for identity ‘SATELLITE’ from [34.254.195.47]:47606
[2019-04-29 08:51:02 +0000] debug/EndpointDbObject: update is_connected=1 for endpoint ‘SATELLITE’
[2019-04-29 08:51:02 +0000] information/ApiListener: Sending config updates for endpoint ‘SATELLITE’ in zone ‘satellite’.
[2019-04-29 08:51:02 +0000] information/ApiListener: Syncing configuration files for zone ‘satellite’ to endpoint ‘SATELLITE’.
[2019-04-29 08:51:02 +0000] notice/ApiListener: Creating config update for file ‘/var/lib/icinga2/api/zones/satellite/_etc/SATELLITE.conf’.
[2019-04-29 08:51:02 +0000] information/ApiListener: Finished sending config file updates for endpoint ‘SATELLITE’ in zone ‘satellite’.
[2019-04-29 08:51:02 +0000] information/ApiListener: Syncing runtime objects to endpoint ‘SATELLITE’.
[2019-04-29 08:51:02 +0000] information/ApiListener: Finished syncing runtime objects to endpoint ‘SATELLITE’.
[2019-04-29 08:51:02 +0000] information/ApiListener: Finished sending runtime config updates for endpoint ‘SATELLITE’ in zone ‘satellite’.
[2019-04-29 08:51:02 +0000] information/ApiListener: Sending replay log for endpoint ‘SATELLITE’ in zone ‘satellite’.
[2019-04-29 08:51:02 +0000] information/ApiListener: Finished sending replay log for endpoint ‘SATELLITE’ in zone ‘satellite’.
[2019-04-29 08:51:02 +0000] information/ApiListener: Finished syncing endpoint ‘SATELLITE’ in zone ‘satellite’.
[2019-04-29 08:51:02 +0000] notice/JsonRpcConnection: Received ‘icinga::Hello’ message from ‘SATELLITE’
[2019-04-29 08:51:02 +0000] notice/JsonRpcConnection: Received ‘pki::RequestCertificate’ message from ‘SATELLITE’
[2019-04-29 08:51:02 +0000] information/JsonRpcConnection: Received certificate request for CN ‘SATELLITE’ signed by our CA.
[2019-04-29 08:51:02 +0000] information/JsonRpcConnection: The certificate for CN ‘SATELLITE’ is valid and uptodate. Skipping automated renewal.
[2019-04-29 08:51:02 +0000] notice/JsonRpcConnection: Received ‘event::SetNextCheck’ message from ‘SATELLITE’
[2019-04-29 08:51:02 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:05 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:05 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:51:05 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:51:07 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:10 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:12 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:12 +0000] notice/JsonRpcConnection: Received ‘event::Heartbeat’ message from ‘SATELLITE’
[2019-04-29 08:51:15 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:15 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:51:15 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:51:17 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:20 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:22 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:22 +0000] notice/JsonRpcConnection: Received ‘event::Heartbeat’ message from ‘SATELLITE’
[2019-04-29 08:51:25 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:25 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:51:25 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:51:27 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:30 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:32 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:32 +0000] notice/JsonRpcConnection: Received ‘event::Heartbeat’ message from ‘SATELLITE’
[2019-04-29 08:51:35 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:35 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:51:35 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:51:37 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:40 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:42 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:42 +0000] notice/JsonRpcConnection: Received ‘event::Heartbeat’ message from ‘SATELLITE’
[2019-04-29 08:51:45 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:45 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:51:45 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:51:47 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:50 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:02
[2019-04-29 08:51:52 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:51:52 +0000] notice/JsonRpcConnection: Received ‘event::Heartbeat’ message from ‘SATELLITE’
[2019-04-29 08:51:52 +0000] notice/JsonRpcConnection: Received ‘event::SetForceNextCheck’ message from ‘SATELLITE’
[2019-04-29 08:51:52 +0000] notice/JsonRpcConnection: Received ‘event::SetNextCheck’ message from ‘SATELLITE’
[2019-04-29 08:51:55 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:52
[2019-04-29 08:51:55 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:51:55 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:51:57 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:52:00 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:51:52
[2019-04-29 08:52:02 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:52:02 +0000] notice/JsonRpcConnection: Received ‘event::Heartbeat’ message from ‘SATELLITE’
[2019-04-29 08:52:03 +0000] notice/JsonRpcConnection: Received ‘event::SetNextCheck’ message from ‘SATELLITE’
[2019-04-29 08:52:03 +0000] notice/JsonRpcConnection: Received ‘event::CheckResult’ message from ‘SATELLITE’
[2019-04-29 08:52:03 +0000] debug/Checkable: Update checkable ‘SATELLITE’ with check interval ‘300’ from last check time at 2019-04-29 08:52:03 +0000 (1.55653e+09) to next check time at 2019-04-29 08:56:49 +0000(1.55653e+09).
[2019-04-29 08:52:03 +0000] debug/DbEvents: add checkable check history for ‘SATELLITE’
[2019-04-29 08:52:04 +0000] debug/IdoMysqlConnection: Query: UPDATE icinga_hoststatus SET acknowledgement_type = ‘0’, active_checks_enabled = ‘1’, check_command = ‘ping4’, check_source = ‘SATELLITE’, check_type = ‘0’, current_check_attempt = ‘1’, current_notification_number = ‘0’, current_state = ‘1’, endpoint_object_id = 217, event_handler_enabled = ‘1’, execution_time = ‘11.009032’, flap_detection_enabled = ‘0’, has_been_checked = ‘1’, host_object_id = 269, instance_id = 1, is_flapping = ‘0’, is_reachable = ‘1’, last_check = FROM_UNIXTIME(1556527923), last_hard_state = ‘1’, last_hard_state_change = FROM_UNIXTIME(1556287325), last_state_change = FROM_UNIXTIME(1556286920), last_time_down = FROM_UNIXTIME(1556527923), last_time_up = FROM_UNIXTIME(1556286627), latency = ‘0.000480’, long_output = ‘’, max_check_attempts = ‘3’, next_check = FROM_UNIXTIME(1556528209), normal_check_interval = ‘5’, notifications_enabled = ‘1’, original_attributes = ‘null’, output = ‘CRITICAL - Plugin timed out’, passive_checks_enabled = ‘1’, percent_state_change = ‘0’, perfdata = ‘’, problem_has_been_acknowledged = ‘0’, process_performance_data = ‘1’, retry_check_interval = ‘1’, scheduled_downtime_depth = ‘0’, should_be_scheduled = ‘1’, state_type = ‘1’, status_update_time = FROM_UNIXTIME(1556527923) WHERE host_object_id = 269
[2019-04-29 08:52:05 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:52:03
[2019-04-29 08:52:05 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:52:05 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:52:07 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:52:10 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:52:03
[2019-04-29 08:52:12 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:52:12 +0000] notice/JsonRpcConnection: Received ‘event::Heartbeat’ message from ‘SATELLITE’
[2019-04-29 08:52:15 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:52:03
[2019-04-29 08:52:15 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:52:15 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:52:17 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:52:20 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:52:03
[2019-04-29 08:52:22 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:52:22 +0000] notice/JsonRpcConnection: Received ‘event::Heartbeat’ message from ‘SATELLITE’
[2019-04-29 08:52:25 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:52:03
[2019-04-29 08:52:25 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:52:25 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:52:27 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:52:30 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:52:03
[2019-04-29 08:52:32 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:52:32 +0000] notice/JsonRpcConnection: Received ‘event::Heartbeat’ message from ‘SATELLITE’
[2019-04-29 08:52:35 +0000] notice/ApiListener: Setting log position for identity ‘SATELLITE’: 2019/04/29 08:52:03
[2019-04-29 08:52:35 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
[2019-04-29 08:52:35 +0000] notice/ApiListener: Connected endpoints: SATELLITE (1)
[2019-04-29 08:52:37 +0000] notice/JsonRpcConnection: Received ‘log::SetLogPosition’ message from ‘SATELLITE’
[2019-04-29 08:52:38 +0000] notice/ApiListener: Creating config update for file ‘/etc/icinga2/zones.d/satellite/SATELLITE.conf’.
[2019-04-29 08:52:38 +0000] notice/ApiListener: Creating config update for file ‘/var/lib/icinga2/api/zones/satellite/_etc/SATELLITE.conf’.
[2019-04-29 08:52:38 +0000] information/ApiListener: Updating configuration file: /var/lib/icinga2/api/zones/satellite//_etc/SATELLITE.conf
[2019-04-29 08:52:38 +0000] debug/ApiListener: Not connecting to Endpoint ‘SATELLITE’ because the host/port attributes are missing.
Thanks,
Louis,
