How do you monitor your switch-stacks via SNMP?
Hello Icinga-Communitiy,
since this is my first post, I beg your pardon for sake of form or something related to this :slightly_smiling_face:
As the caption mentions, I am interested in best-practices for monitoring switch-stacks.
The check_nwc_health plugin works totally fine, but not when it comes down to monitoring a stack of switches - at least with Huawei Cloud Engine switches.
As you see, the load and memory checks are working properly.
The SNMP Health check (-- mode hardware_health) delivers an unknown state.
Do you have any ideas how to get the hardware_health information?
I really would like to stick to one SNMP-Plugin and don’t mix them.
Good day, which SNMP version are you working with? I can imagine that you have made a mistake in your SNMP configuration on the master or the switch.
Hi and welcome,
do you use check_nwc_health also for your other checks (SNMP Load, SNMP Memory)?
It would also help a lot if you show us your service definition
I use SNMP v3.
Here are the checks executed via shell.
The upper two checks are asking the stack, the other two a single switch.
Thank you
Interesting that the other modes works fine. only the mode for hardware-health fails.
You could try follwoing:
  • for the mode hardware-health use another timeout with the param --timeout.
  • run a snmpwalk to the specific oids. The oids should be included in the script. What happens here?
Hello Stevie,
the timeout hint made it - I set the value to 60.
Obviously the check needs too much time to check five switches.
Thanks for your help
