Does anyone have idea about adding servers in Icinga2 for monitoring?
Thanks,
Sai
Thanks,
Sai
You can start by reading these docs:
https://icinga.com/docs/icinga-2/latest/doc/02-installation/
https://icinga.com/docs/icinga-2/latest/doc/03-monitoring-basics/
https://icinga.com/docs/icinga-2/latest/doc/04-configuration/
If you want to make your life easier (at least that’s what I think it’s easier), you can install the icinga director module which can help you with the configurations.
Mike
