I don’t like the new default theme and i dont like the default theme mode ist dark. How can i enforce the “light” mode for every user and not only under accounts?
Icinga modules already have support for both modes. Director will get an update soon as well. If you have your own modules, you should invest time in adjusting these. (As described here)
If you have no time for this now, Icinga Web 2.10 is no mandatory upgrade, stay on 2.9.x then.
Specifically, I have a problem with the dark/light mode of the grafana module. I have set this to light. The graph is rendered white, even if Icinga is in dark mode, which just looks stupid. The problem is more with the module and grafana, but it’s still annoying. The light mode compensates for this a bit.
Thanks, looks good. As far as I can see it only fixes the menu, not the graph color itself, see Modules > grafana > Configuration >“Grafana Theme” = Dark or Light.
Of course this can’t be fixed by Icingaweb, but Dark or Light should be able to be set depending on the Theme Mode. So again the module author.
I don’t like the dark mode either. As a workaround I tried to create a new theme with fixed light mode. However, this new theme inherits dark mode only. Is there any documentation how to inherit the default light mode in a new theme?
