Hello everyone, I have a question, how can I add the zone of a host as a variable (vars.zone) in my hosts.conf file or in the one that corresponds (I do not occupy icinga director) so that I can monitor the location through the module maps
Hi mauro,
every Host object holds a variable zone which contains the zone the object is a member of:
https://icinga.com/docs/icinga-2/latest/doc/09-object-types/#host
Does that help you?
Best regards,
Daniel
