Cloned active and working configured host.
The new one is stuck in Pending state.
When I press Inspect I get this:
First parameter must either be an object or the name of an existing class (IcingaObjectInspection.php:60)
#0 [internal function]: Icinga\Application\ApplicationBootstrap->Icinga\Application{closure}(2, ‘First parameter…’, ‘/usr/share/icin…’, 60, Array) #1 /usr/share/icingaweb2/modules/director/library/Director/Web/Widget/IcingaObjectInspection.php(60): property_exists(NULL, ‘command’) #2 /usr/share/icingaweb2/modules/director/library/Director/Web/Widget/IcingaObjectInspection.php(45): Icinga\Module\Director\Web\Widget\IcingaObjectInspection->renderLastCheckResult(NULL) #3 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Html/HtmlDocument.php(232): Icinga\Module\Director\Web\Widget\IcingaObjectInspection->assemble() #4 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Html/BaseHtmlElement.php(194): dipl\Html\HtmlDocument->ensureAssembled() #5 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Html/HtmlDocument.php(193): dipl\Html\BaseHtmlElement->renderUnwrapped() #6 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Html/HtmlDocument.php(250): dipl\Html\HtmlDocument->render() #7 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Html/BaseHtmlElement.php(175): dipl\Html\HtmlDocument->renderUnwrapped() #8 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Html/BaseHtmlElement.php(198): dipl\Html\BaseHtmlElement->renderContent() #9 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Html/HtmlDocument.php(193): dipl\Html\BaseHtmlElement->renderUnwrapped() #10 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Html/HtmlDocument.php(262): dipl\Html\HtmlDocument->render() #11 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Zf1/SimpleViewRenderer.php(47): dipl\Html\HtmlDocument->__toString() #12 /usr/share/icingaweb2/modules/director/library/vendor/ipl/Zf1/SimpleViewRenderer.php(66): dipl\Zf1\SimpleViewRenderer->render() #13 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action/HelperBroker.php(272): dipl\Zf1\SimpleViewRenderer->postDispatch() #14 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action.php(518): Zend_Controller_Action_HelperBroker->notifyPostDispatch() #15 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch(‘objectAction’) #16 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response)) #17 /usr/share/php/Icinga/Application/Web.php(300): Zend_Controller_Front->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response)) #18 /usr/share/php/Icinga/Application/webrouter.php(104): Icinga\Application\Web->dispatch() #19 /usr/share/icingaweb2/public/index.php(4): require_once(’/usr/share/php/…’) #20 {main}
