Afternoon,
I’ve made it onto deploying a 3 tier setup. Previous I used a master <-> agent style configuration for my local devices. However I’m now extending to cover remote offices.
So far I’ve managed to get a Satellite server installed on a remote office site and connected with a new zone to the Master via Director (v2.11.x) I wasn’t sure about the reported bug so just continued. I’ve also deployed a simple ping check to the gateway on the remote site, which is being executed by the Satellite.
However, I’m a little unsure how to name my checks. The ping check isn’t clear where the source is, only the resultant destination. What happens if I want to ping the same target/host from multiple sources?
I guess I’m not totally understanding the architecture. Do I need to add the target/host multiple times? if so do you name it based on source->destination etc.
Views and opinions would be appreciated. I guess i’m missing something,
