Hello
I’m very new to Icinga and I’m trying to use a different check_interval value depending on the host the check is run on.
I’ve created a custom variable (Data Field) in Icinga Director and added it to my host template. Then I filled in the values for every relevant host.
I thought I could then reverence the variable in the service templates ‘check_interval’ field like so:
$host.vars.specific_check_interval$
However when I try to store that change, nothing happens. I assume I messed up the syntax somehow or that it simply isn’t possible to use a host variable in the ‘check_interval’ field.
How can I fix this? Is there another way to achieve the same result?
Thanks and greetings
