i have a question how to hook the monitoring integration from the vsphere module into a fresh icingadb installation?
For example like in this live demo (minute 23:00):
For example in my test installation i can only select IDO as source type. But i don’t have IDO installed, because my monitoring module is disabled and i only use the icingadb module:
Thank you
