Here I am again, when I click on the web interface on history I only get sql-syntax … that´s not what I would like to see … anybody have some ideas?
Greetings
You have been trying so many changes during your session and maybe your database(s) got screwed up. I’d recommend to to drop them all and recreate a empty but clean database:
# systemctl stop icinga2
# mysql -u root -p
DROP DATABASE icinga;
CREATE DATABASE icinga;
exit
# mysql -u root -p icinga < /usr/local/share/icinga2-ido-mysql/schema/mysql.sql
# systemctl start icinga2
(adapt the name of the database to your needs)
What will happening with my monitoring, when i do this?
All of my configuration will be away, or?
You will lose your history. Your config is not defined in the database but conf files, right?
Wait a moment. I didn’t follow the previous discussion, but before you purge your database please tell me the following:
latin1 if notIt works, thank you!
