Hello
I am trying to deploy Nagvis in icinga2 to finally try to integrate a map in dashboard dashing-icinga2.
I have first tried to deploy Nagvis, following the guide in the repository:
https://github.com/Icinga/icingaweb2-module-nagvis/blob/master/doc/02-Installation.md
I didn’t succeed and there are configurations that I don’t understand or are incomplete:
where is the file nagvis.ini.php? Because when I installed the module from Git I could not find it in that directory, another directory is not mentioned in the installation.
I can’t find the core.php file either, in the documentation it says it is located in:
/share/server/core/functions/core.php
But I can’t find it in the folder downloaded from Git either.
Is there any other installation or files that are not listed in the Github installation guide?
Best regards.
