Hardware and software requirements for installing Icinga
Hi Everyone
I am very new to Icinga. For the first time I am going to set up icinga. I need to prepare System specifications document. Please help me with the software/hardware specifications/requirements for installing icinga 2 and also for other components which need to be installed along with Icinga.
Thanks in advance
Thanks&Regards
Srinivas
A lot of suggestions can be made but we need a little more info on the target infrastructure. e.g:
  • How many hosts will be monitored?
  • Operating systems?
  • Hardware , Virtualization and/or containers?
  • Network information, subnets etc
  • Guesstimates on services per host
  • Databases and other important services
  • plus whatever else you consider important
George
Hi George,
Thanks you so much for prompt response. I will provide the above information.
Thanks&Regards
Srinivas
Hi George,
I am trying to gather the above information while could you please provide me the information on how many servers are required to set up Icinga? and also what mandatory components to be installed.
Thanks&Regards
Thanks&Regards
A single icinga2 Core and Icingaweb2 instance plus database and graphite/grafana can monitor hundreds of hosts and thousands of services with just 4 vCPU, 8 GB mem and 30GB of disk.
If you can use zones and satellites that spread the load, the numbers can even be lower.
I would suggest checking out the pre-configured vagrant-boxes for setup examples
George
Hi George,
Thank you so much for the information
Thanks&Regards
Srinivas
