hello,
i am currently trying to set up a highly available icinga satellite zone. all of the nodes in the network receive their icinga configuration from puppet, i.e. we do not use the icinga configuration synchronization mechanics (the conf.d directory is absent everywhere). all the tutorials, howtos and documentation usually recommend and describe the icinga setup using config sync, but make no remarks if this is the only possible way to achieve it. (apart from using icinga director)
adding a second endpoint to the satellite zone causes certain check results for the client to never make it to the master (at least in icingaweb2 the Next check timer is in the past). i assume the affected checks are the ones the secondary satellite schedules.
the zones.conf is identical on icinga-satellite01-test.example.com and icinga-satellite02-test.example.com
object Endpoint "icinga-client01-test.example.com" {
host = "icinga-client01-test.example.com"
log_duration = 0
object Endpoint "icinga-satellite01-test.example.com" {
host = "icinga-satellite01-test.example.com"
log_duration = 3600
object Endpoint "icinga-satellite02-test.example.com" {
host = "icinga-satellite02-test.example.com"
log_duration = 3600
object Endpoint "icinga-master01-test.example.com" {
log_duration = 0
global = true
global = true
object Zone "icinga-client01-test.example.com" {
endpoints = [ "icinga-client01-test.example.com", ]
parent = "test"
object Zone "master" {
endpoints = [ "icinga-master01-test.example.com", ]
object Zone "test" {
endpoints = [ "icinga-satellite01-test.example.com", "icinga-satellite02-test.example.com", ]
parent = "master"
because we use puppet to manage the configuration in /etc/icinga2, accept_config is set to false
object ApiListener "api" {
accept_commands = true
accept_config = false
the log on the secondary satellite (icinga-satellite02-test.example.com) shows at least connectivity between the involved endpoints:
notice/ApiListener: Current zone master: icinga-satellite01-test.example.com
notice/ApiListener: Connected endpoints: icinga-client01-test.example.com (1), icinga-satellite01-test.example.com (1) and icinga-master01-test.example.com (1)
the zone master (icinga-satellite01-test.example.com) rejects the results:
notice/ClusterEvents: Discarding ‘next check changed’ message for checkable ‘icinga-client01-test.example.com!memory’ from ‘icinga-satellite02-test.example.com’: Unauthorized access.
the satellites and client hosts use icinga2 r2.10.4-1
later on we would also like to set up the master zone with two nodes, although i have no idea yet how to synchronize icinga objects which are not managed by puppet (announcements, acknowledgements, downtimes)
