I have a question about HA icinga2 and agent connection direction.
I am current testing HA in a test environment and in my production environment my agents connect to the master.
object Endpoint "nms.internal" {
host = "nms.internal"
object Zone "master" {
endpoints = [ "nms.internal" ]
global = true
global = true
/* Individual hosts */
object Endpoint "agent.internal" {
object Zone "agent.internal" {
endpoints = [ "agent.internal" ]
parent = "master"
Now once I deploy HA, is it possible to still have that connection direction? and it possible is a problem?
object Endpoint "master01.internal" {
host = "172.30.0.136"
object Endpoint "master02.internal" {
host = "172.30.0.137"
endpoints = [ "master01.internal","master02.internal" ]
parent = "master"
global = true
global = true
- Version used (
icinga2 --version) r2.12.4-1 - Operating System and version 20.04.1 LTS (Focal Fossa)
- Enabled features (
icinga2 feature list) api checker ido-mysql influxdb mainlog notification - Icinga Web 2 version and modules (System - About) 2.8.2
- Config validation (
icinga2 daemon -C) valid - If you run multiple Icinga 2 instances, the
zones.conffile (oricinga2 object list --type Endpointandicinga2 object list --type Zone) from all affected nodes
config master
object Endpoint "nmstest01.agilitypr.internal" {
object Endpoint "nmstest02.agilitypr.internal" {
endpoints = [ "nmstest01.agilitypr.internal","nmstest02.agilitypr.internal" ]
global = true
