Hi there,
i have follow the Manual for install Graphite on Debian 10. But i get no Graphics in Composer.
/etc/graphite/local_settings.conf
SECRET_KEY = 'Sha0zoh6aeM9duaZJeed0shoahNi0oMe'
ALLOWED_HOSTS = [ '*' ]
TIME_ZONE = 'Europe/Berlin'
LOG_ROTATION = True
LOG_FILE_INFO = 'info.log'
LOG_FILE_EXCEPTION = 'exception.log'
LOG_FILE_CACHE = 'cache.log'
LOG_FILE_RENDERING = 'rendering.log'
DEBUG = True
DEFAULT_XFILES_FACTOR = 0
GRAPHITE_ROOT = '/usr/share/graphite-web'
CONF_DIR = '/etc/graphite'
STORAGE_DIR = '/var/lib/graphite/whisper'
STATIC_ROOT = '/usr/share/graphite-web/static'
LOG_DIR = '/var/log/graphite'
INDEX_FILE = '/var/lib/graphite/search_index'
WHISPER_DIR = '/var/lib/graphite/whisper'
DATABASES = {
'default': {
'NAME': '/var/lib/graphite/graphite.db',
'ENGINE': 'django.db.backends.sqlite3',
'USER': '',
'PASSWORD': '',
'HOST': '',
'PORT': ''
FUNCTION_PLUGINS = []
/etc/carbon/carbon.conf:
[cache]
STORAGE_DIR = /var/lib/graphite/
LOCAL_DATA_DIR = /var/lib/graphite/whisper/
CONF_DIR = /etc/carbon/
LOG_DIR = /var/log/carbon/
PID_DIR = /var/run/
DATABASE = whisper
ENABLE_LOGROTATION = False
USER = _graphite
MAX_CACHE_SIZE = inf
MAX_UPDATES_PER_SECOND = 500
# MAX_UPDATES_PER_SECOND_ON_SHUTDOWN = 1000
MAX_CREATES_PER_MINUTE = 50
MIN_TIMESTAMP_RESOLUTION = 1
# MIN_TIMESTAMP_LAG = 0
LINE_RECEIVER_INTERFACE = 127.0.0.1
LINE_RECEIVER_PORT = 2003
ENABLE_UDP_LISTENER = False
UDP_RECEIVER_INTERFACE = 127.0.0.1
UDP_RECEIVER_PORT = 2003
PICKLE_RECEIVER_INTERFACE = 127.0.0.1
PICKLE_RECEIVER_PORT = 2004
PICKLE_RECEIVER_MAX_LENGTH = 1048576
# PROTOBUF_RECEIVER_INTERFACE = 127.0.0.1
# PROTOBUF_RECEIVER_PORT = 2005
#MAX_RECEIVER_CONNECTIONS = inf
USE_INSECURE_UNPICKLER = False
CACHE_QUERY_INTERFACE = 127.0.0.1
CACHE_QUERY_PORT = 7002
USE_FLOW_CONTROL = True
#METRIC_CLIENT_IDLE_TIMEOUT = None
LOG_UPDATES = False
LOG_CREATES = False
LOG_CACHE_HITS = False
LOG_CACHE_QUEUE_SORTS = False
CACHE_WRITE_STRATEGY = sorted
WHISPER_AUTOFLUSH = False
# WHISPER_SPARSE_CREATE = False
WHISPER_FALLOCATE_CREATE = True
WHISPER_LOCK_WRITES = True
# WHISPER_FADVISE_RANDOM = False
# CERES_NODE_CACHING_BEHAVIOR = all
# CERES_SLICE_CACHING_BEHAVIOR = latest
# CERES_MAX_SLICE_GAP = 80
# CERES_LOCK_WRITES = False
# USE_WHITELIST = False
CARBON_METRIC_PREFIX = carbon
CARBON_METRIC_INTERVAL = 60
# GRAPHITE_URL = http://127.0.0.1:8000
[cache:b]
LINE_RECEIVER_PORT = 2103
PICKLE_RECEIVER_PORT = 2104
CACHE_QUERY_PORT = 7102
[relay]
LINE_RECEIVER_PORT = 2013
PICKLE_RECEIVER_PORT = 2014
#RELAY_METHOD = rules
#RELAY_METHOD = consistent-hashing
#RELAY_METHOD = aggregated-consistent-hashing
REPLICATION_FACTOR = 1
# TAG_RELAY_NORMALIZED = False
# DIVERSE_REPLICAS = True
# DESTINATIONS = 127.0.0.1:2004
DESTINATIONS = 127.0.0.1:2004:a, 127.0.0.1:2104:b
DESTINATION_PROTOCOL = pickle
DESTINATION_TRANSPORT = none
# DESTINATIONS_POOL_REPLICAS = False
# DYNAMIC_ROUTER = False
# DYNAMIC_ROUTER_MAX_RETRIES = 5
MAX_QUEUE_SIZE = 10000
MAX_DATAPOINTS_PER_MESSAGE = 500
USER = _graphite
QUEUE_LOW_WATERMARK_PCT = 0.8
TIME_TO_DEFER_SENDING = 0.0001
# LOG_LISTENER_CONN_SUCCESS = True
USE_RATIO_RESET=False
MIN_RESET_STAT_FLOW=1000
MIN_RESET_RATIO=0.9
MIN_RESET_INTERVAL=121
# TCP_KEEPCNT=2
[aggregator]
LINE_RECEIVER_PORT = 2023
PICKLE_RECEIVER_PORT = 2024
FORWARD_ALL = True
# AGGREGATION_RULES = aggregation-rules.conf
# REWRITE_RULES = rewrite-rules.conf
MAX_AGGREGATION_INTERVALS = 5
# WRITE_BACK_FREQUENCY = 0
# LOG_AGGREGATOR_MISSES = False
USER = _graphite
# CACHE_METRIC_NAMES_MAX=1000000
# CACHE_METRIC_NAMES_TTL=600
Icinga Web 2 Version |2.11.3|
PHP Version |8.1.12|
graphite 1.2.1
OS: Debian Bookworm ARM64 on RAspberry PI 4
I did not find al Solutin, maybe give me a little help…
Sincelrey Uwe
