HI,
i have integrated the graphite feature on my icingaweb2. Connected the backend graphite url as well and enabled graphite too but on my graphite dashboard on icingaweb2 it shows no graphs found.
Find attached shot
A few ideas come to mind
If you don’t see any metrics in the graphite web app that’s the root issue. If you have metrics maybe you need to adjust your templates (read the module documentation).
If you have problems with a particular graph add: “&graph_debug=1” to the URL and graphite will display a step by step of the building process.
Good luck
