Author: @mfriedrich
Version: v0.1Tested with:
- Graphite 1.1.5 in Vagrant, requires #175
Context
While reading a question about the Graphite web module integration and templates, I’ve found out that current versions of Graphite also allow to extend the Render API with custom functions.
This can be used to extend the Graphite API and use these functions from the web module’s templates.
Resources
Implementation
Preparations
Vagrant with Graphite
Take the Icinga Vagrant box “standalone” which provisions Graphite already.
git clone https://github.com/icinga/icinga-vagrant
cd icinga-vagrant/standalone
vagrant up
Inspect the Render API
Open Grafana and pick a metric from the dashboard. Then adopt this into a render API target like this:
Inspect existing Functions
http://192.168.33.5:8003//functions?pretty=1
Core function code is located in /opt/graphite/webapp/graphite/render/functions.py and allows to understand the ideas, or copy something.
Example
Custom Function to replace Underscores in Metric Names
Navigate into /opt/graphite/webapp/graphite/functions/custom and start your work.
vagrant ssh
sudo -i
cd /opt/graphite/webapp/graphite/functions/custom
vim formathostlegend.py
from graphite.functions.params import Param, ParamTypes
def formatHostLegend(requestContext, seriesList):
"""Custom function that prints a pretty-fied legend name"""
for series in seriesList:
pos = series.name.find(".perfdata")
first = series.name[0:pos]
second = series.name[pos:]
series.name = first.replace('_', '.') + second
return seriesList
# Define group
formatHostLegend.group = 'Custom'
# Define parameters for the callback
formatHostLegend.params = [
Param('seriesList', ParamTypes.seriesList, required=True)
# Register the callback function
SeriesFunctions = {
'formathostlegend': formatHostLegend
Restart Graphite Web / Apache
systemctl restart httpd
Verify the Function
Navigate to http://192.168.33.5:8003//functions?pretty=1 and search for the exported function.
Test the Function
Your implementation?
Please share your custom functions and more with the Graphite Render API ![]()
