I configured the Graphite module on Icinga2 and Icingaweb2.
It works and some graphs are shown on Icingaweb2, but I realized that not all performance data are exported to Graphite.
For example, these are the performance data for the LinuxFabrik ping plugin:
"transmitted=5;;;0;",
"received=5;;;0;",
"duplicates=0;;;0;",
"checksum_corrupted=0;;;0;",
"errors=0;;;0;",
"packet_loss=0%;;;0;100",
"time=806ms;;;0;",
"rtt_min=20.262ms;;;0;",
"rtt_avg=20.852ms;;;0;",
"rtt_max=21.357ms;;;0;",
"rtt_mdev=0.427ms;;;0;"
But I see only the rtt_mdev metric:
This reflects what is indexed on Graphite:
This problems happens on basically all plugins, and some plugins are completely missing on Graphite, even if they are generating perfdata, for example the disk-usage plugin:
"/-usage=3911393280B;;;0;17864896512",
"/-total=17864896512B;;;0;17864896512",
"/-percent=23.1%;;;0;100",
"/boot-usage=161774592B;;;0;467879936",
"/boot-total=467879936B;;;0;467879936",
"/boot-percent=36.9%;;;0;100",
"/tmp-usage=90112B;;;0;3851608064",
"/tmp-total=3851608064B;;;0;3851608064",
"/tmp-percent=0.0%;;;0;100",
"/var-usage=3954708480B;;;0;33631780864",
"/var-total=33631780864B;;;0;33631780864",
"/var-percent=12.4%;;;0;100",
"/var/lib/postgresql-usage=2157281280B;;;0;210237366272",
"/var/lib/postgresql-total=210237366272B;;;0;210237366272",
"/var/lib/postgresql-percent=1.1%;;;0;100"
Could you help me to find out where I’m wrong, please?
Thank you!
