Hi there,
I have the graphite module enabled but the graphs are not showing correctly. This is how it looks like
The actual icinga web does not have any certificate, should I install one on the virtual host? could you point me to the correct file ??
root@srvfpamonp02:/etc/apache2# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.11.2-1)
Copyright (c) 2012-2019 Icinga GmbH (https://icinga.com/)
System information:
Platform: Ubuntu
Platform version: 16.04.6 LTS (Xenial Xerus)
Kernel: Linux
Kernel version: 4.4.0-159-generic
Architecture: x86_64
Build information:
Compiler: GNU 5.4.0
Build host: runner-LTrJQZ9N-project-298-concurrent-0
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
Disabled features: debuglog elasticsearch gelf icingastatus influxdb opentsdb statusdata syslog
Enabled features: api checker command compatlog graphite ido-mysql livestatus mainlog notification perfdata
root@srvfpamonp02:/etc/apache2# icinga2 daemon -C
[2019-11-25 12:05:26 +0100] information/cli: Icinga application loader (version: r2.11.2-1)
[2019-11-25 12:05:26 +0100] information/cli: Loading configuration file(s).
[2019-11-25 12:05:26 +0100] information/ConfigItem: Committing config item(s).
[2019-11-25 12:05:26 +0100] information/ApiListener: My API identity: srvfpamonp02
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 LivestatusListener.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 3 NotificationCommands.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 NotificationComponent.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 12 Notifications.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 18 HostGroups.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 65 Hosts.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 4 EventCommands.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 GraphiteWriter.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 PerfdataWriter.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 3 Zones.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 Endpoint.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 ExternalCommandListener.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 ApiUser.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 2 UserGroups.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 CompatLogger.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 257 CheckCommands.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 3 TimePeriods.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 2 Users.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 75 Services.
[2019-11-25 12:05:26 +0100] information/ConfigItem: Instantiated 7 ServiceGroups.
[2019-11-25 12:05:26 +0100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2019-11-25 12:05:26 +0100] information/cli: Finished validating the configuration file(s).
