to be honest I am a complete noob to all this fance python-etc-stuff…
And although having years of experience with webservers and modules and icinga, nagios, netsaint I am really struggeling with graphite under ubuntu with nginx…
Has anybody experience / a good howto about this?
Everything I found was with apache but not nginx (which seems to make a real difference for graphite-web…) or important details are completely missing…or…or…or…
What I got running: seems to be service data send to graphite / carbon backend, I see databases growing and named after services…
What I got not running: graphite-web module accessible through nginx (and therefor not showing in icingaweb2)…
I have implemented the graphite module on Ubuntu and RH, and found that there was an issue with the nginx frontend forwarding and reading, so in the end I run the graphite-web as a standalone systemd unit and connected directly to it ( as it is an internal system we did not had the need for the extra layer of the nginx/ apache requirement)
Can you share your nginx and graphite module config ?
Similarly to Assaf, I point icingaweb’s graphite module directly at Gunicorn instead of Nginx (typically ipaddress:8000) and that works fine. For Graphite’s web portal specifically, you’ll need to make sure you forward the static content (described in that documentation) with Nginx. Here’s my systemd module:
Naturally change paths accordingly. I install Graphite with pip and I’m not familiar with how Ubuntu lays it out (if at all). Your graphite_wsgi file should be in the webapp directory that parents graphite-web’s folder. That mess should summarize some headache I dealt with outside of the official documentation, let me know if you need anything clarified.
Additionally, check the local_settings.py file. That’s a standard thing with Django and if you need to configure any custom URIs before setting up a reverse proxy (URL_PREFIX=/graphite for example), that can be handled there.
Thanks for sharing this config, unfortunately I didn’t get it run with Ubuntu 18.04 though.
There are always issues by getting the provided graphite.wsgi running (some Python errors…).
