Hi everyone,
this posting is a duplicate from the raspberrypi.org forum.
In short: I’m trying to build a Raspberry Pi instance with the following software stack:
- Icinga2
- Grafana
- Graphite + Carbon + Wisper
My problem is that the packages graphite and graphite-web are both version version 0.9.15-1. Both packages are delivered from the offical Raspberry/Debian 9 projekt itself and the versions are too old to work correctly with the Django 1:1.10.7-2+deb9u4 that is coming from the same repository too.
The full error message is:
root@pi:~# graphite-manage runserver
Performing system checks...
Unhandled exception in thread started by <function wrapper at 0x75ddd630>
Traceback (most recent call last):
File "/usr/lib/python2.7/dist-packages/django/utils/autoreload.py", line 226, in wrapper
fn(*args, **kwargs)
File "/usr/lib/python2.7/dist-packages/django/core/management/commands/runserver.py", line 121, in inner_run
self.check(display_num_errors=True)
File "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line 374, in check
include_deployment_checks=include_deployment_checks,
File "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line 361, in _run_checks
return checks.run_checks(**kwargs)
File "/usr/lib/python2.7/dist-packages/django/core/checks/registry.py", line 81, in run_checks
new_errors = check(app_configs=app_configs)
File "/usr/lib/python2.7/dist-packages/django/core/checks/urls.py", line 14, in check_url_config
return check_resolver(resolver)
File "/usr/lib/python2.7/dist-packages/django/core/checks/urls.py", line 24, in check_resolver
for pattern in resolver.url_patterns:
File "/usr/lib/python2.7/dist-packages/django/utils/functional.py", line 35, in __get__
res = instance.__dict__[self.name] = self.func(instance)
File "/usr/lib/python2.7/dist-packages/django/urls/resolvers.py", line 315, in url_patterns
patterns = getattr(self.urlconf_module, "urlpatterns", self.urlconf_module)
File "/usr/lib/python2.7/dist-packages/django/urls/resolvers.py", line 308, in urlconf_module
return import_module(self.urlconf_name)
File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
__import__(name)
File "/usr/lib/python2.7/dist-packages/graphite/urls.py", line 29, in <module>
urlpatterns = patterns('',
NameError: name 'patterns' is not defined
According to graphite-web issue #1816 the django is too new for the graphite.
My questions are:
- How to fix this? Building a virtual-env seems a little bit to complicated to maintain.
- Has anybody a newer package for graphite for the Pi?
- Is there an easy way to build packages for the Pi?
- Has anybody has a Raspberry running with any kind of graphs?
