+ Icinga check command: 'Invoke-IcingaCheckCPU'
+ Obscured check command: NULL
+ Applying templates for check command 'Invoke-IcingaCheckCPU'
++ Applying template 'load-windows'
+++ Fetched 0 metric(s) from 'http://127.0.0.1:81/metrics/expand?query=icinga2.server01_local.services.windows-Invoke-IcingaCheckCPU.Invoke-IcingaCheckCPU.perfdata.%2A.value'
+++ Fetched 0 metric(s) from 'http://127.0.0.1:81/metrics/expand?query=icinga2.server01.services.windows-Invoke-IcingaCheckCPU.Invoke-IcingaCheckCPU.perfdata.%2A.crit'
+++ Fetched 0 metric(s) from 'http://127.0.0.1:81/metrics/expand?query=icinga2.server01.services.windows-Invoke-IcingaCheckCPU.Invoke-IcingaCheckCPU.perfdata.%2A.warn'
+++ Excluded 0 metric(s)
+++ Combined 0 metric(s) to 0 chart(s)
+ Applying default templates, excluding previously used metrics
++ Not applying template 'multi2-host'
++ Applying template 'multi2-service'
+++ Fetched 0 metric(s) from 'http://127.0.0.1:81/metrics/expand?query=icinga2.server01.windows-Invoke-IcingaCheckCPU.Invoke-IcingaCheckCPU.perfdata.%2A.%2A.value'
++ Not applying template 'multi3-host'
++ Applying template 'multi3-service'
+++ Fetched 3 metric(s) from 'http://127.0.0.1:81/metrics/expand?query=icinga2.server01.services.windows-Invoke-IcingaCheckCPU.Invoke-IcingaCheckCPU.perfdata.%2A.%2A.%2A.value'
+++ Excluded 3 metric(s)
++ Not applying template 'default-host'
++ Applying template 'default-service'
+++ Fetched 0 metric(s) from 'http://127.0.0.1:81/metrics/expand?query=icinga2.server01.windows-Invoke-IcingaCheckCPU.Invoke-IcingaCheckCPU.perfdata.%2A.value'
I see that i applies the template ‘default-service’… It seems not to apply the template ‘cpu_windows_powershell_framework.ini’ which I suppose should be the correct one? Is that maybe the problem?
I saw some notes regarding storage-aggregation.conf, but I actually don’t have any such file at all in the /etc/carbon directory… I was following different setup guides so maybe I’ve missed some part?
I see older data on the CPU graphs, which was the ones we fixed before… so maybe the only thing I need to do is to set storage-schema to:
[icinga2_default]
pattern = ^icinga2.
retentions = 1m:2d,5m:10d,30m:90d,360m:4y
Then run the whisper-resize tool ? but how should I then run that?
