Hello to All,
i have Grafana Server Version 6.6.1 (commit: 21bf8b71bc, branch: HEAD) on the Server, but it don’t work with Google Chrome 80. Firefox, IE and Edge works fine.
The Configuration is on Port 3000
Error Message: The website is unavailable
The website at https://server:3000/ may be temporarily unavailable or has been permanently moved to a new web address.
The same configuration works with Firefox, … but not with Chrome 80, 79, …
Plugin for Icinga2: icingaweb2-module-grafana
Error Log in the Plugin Window: Die Webseite unter https://server.de:3000/d-solo/ygBKcmTZz/disk?var-hostname=dcdedacpo007.mn-man.biz&var-service=Check%20Disk%20Var%20Log&var-command=disk&panelId=1&orgId=1&theme=light&from=now-6h&to=now ist eventuell vorübergehend nicht verfügbar oder wurde dauerhaft an eine neue Webadresse verschoben.
This is from apache error_log
[ssl:warn] [pid 2581] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
Has anyone a Tipp for me
