Grafana Module
I defined manually a lot of graphs templates in the “Grafana Graphs” menu on the master satellite pointing to different dashboards from the grafana server. (see attached image )
Is there a possibility to replicate automatically this graphs on the secondary satellites?
Petre
Hi Petre,
They should be stored in the configuration files at /etc/icingaweb2/modules/grafana. I don’t have the module installed so I can’t test it right now.
You can use tools like rsync to synchronize them from a primary node to a secondary node. If you want bidirectional sync you can use csync2.
Hi Thomas,
I copied the file /etc/icingaweb2/modules/grafana/graphs.ini from the master to satellites.
Now the graphs are now available on all servers .
In the future i will think about to use rsync to synchronize them from primary node to secondary nodes. Thank you for this idea .
Petre
