Grafana module for IcingaWeb2 with proxy mode and icingadb possible?
we are upgrading to Icingadb. We tried to use the proxy mode as not all users have access to grafana, but it lools like the proxymode is not working on icingadb, as the link from the icinagweb2-grafana module is still pointing to the monitong module.
Is this not possible yet and we need to stay on iFrame for the moment?
Thanks for support and best regards,
Rafael
Hi Rafael,
If I remember correctly the proxy mode with Icingadb should also be possible.
Hi David,
yes, it should, but the links are simply not working because of missing dependences with the monitoringmodule. It tries to use the monitoring module, but that is not enabled because of icingadb.
Hi Rafael,
i had found the following issue on Github. I currently have Grafana disabled because I am still testing icingadb in a test environment. If necessary I will follow this “improvised” solution.
Error “Enabling the monitoring module might help!” when changing the time interval in the embebed graph in icingadb module · Issue #295 · Mikesch-mp/icingaweb2-module-grafana (github.com)
