Grafana IRM for notifications
Grafana has their own pager service called Grafana IRM now, and I can’t find any docs or tools regarding using it with Icinga2. Anyone already worked something out? I’m going to get it working and documented otherwise; trying not to duplicate efforts. Grafana webhook docs seem straightforward.
Got a working script, but wondering if I should write an agent like PagerDuty and OpsGenie have instead. Will publish the code in the next couple days after some cleanup and then mark this resolved.
Would love to look into this at some point :slight_smile:
Have you looked into Icinga Notifications yet?
Honestly, new features fly over my head because I moved to a company that doesn’t use it. I’ve got personal Icinga and Prometheus servers that monitor each other and I’m coping with OpsGenie EOL.
Looking at it now, I see it’s written in Go, which I’m pretty handy with. I’m still going to roll this easy way out first because I need it, but I could probably PR some channels if I get bored over the holidays. edit: I see the “don’t replace webhooks” advisory, but I know of others.
Quick and easy. I’ll try out Icinga Notifications later. Grafana IRM Notification Command for Icinga2 (and maybe Nagios) · GitHub
great to here and thanks for sharing.
I had a quick look and found some inconsistencies:
upstream_link = f"{icinga_url}dashboard#!/icinga2/icingadb/service?name={service_parsed}?host.name={host_parsed}"
this would render the icingaweb2 dashboard on the left and the service on the right.
but assuming this `{icinga_url}` is https://icinga.local/icingaweb2/ the second part of the url only works if your instance is https://icinga.local/icinga2/
Oh it reuses that? Okay. Know off hand the generic URL? I just copied/pasted from my browser url an alert I was testing with to be honest. Have no problem adjusting that in the gist after work.
Per default Icinga Web uses /icingaweb2/ as its root. IcingaDB Web uses /icingaweb2/icingadb/
Took out the #dashboard/icingapath/ part of the URL in the gist, should be cleaner now. Example already has using /icingapath/ as part of your provided url.
