Wonder if there is any Grafana dashboards out there which shows the Icinga2 Infra performance stats… Masters, IDO, Satellites. I couldn’t find one online. I probably should look into creating my own dashboard but checking if someone has one already.
I think the problem here is that most, if not all of the icinga specific checks that come out of the box don’t have perf data.
I could be wrong, but glancing at my stuff, it doesn’t.
If you’re using Graphite, here’s one you could use (at least as a starting point):
Thank you for sharing that. Yes,it is a good start.
