to get the IcingaAgentVersion I can call
get-icngaagentversion
How can I get the version form the
icinga-powershell-framework and icinga-powershell-plugins
if there is also a own command in the framework, I don’t know.
But you can use base commands from PowerShell: Get-InstalledModule -Name icinga-powershell-framework | Select Version
or Get-Module -name icinga-powershell-framework -ListAvailable | Select Version
get-installedmodule show me not the icinga-powershell-framework that is in this folder “c:\Program Files\WindowsPowerShell\Modules\icinga-powershell-framework”
that is my solution for the question (thanks stevie sy … your answer help me to find my solution)
get-module -ListAvailable |where {$.name -like “icinga-powershell-framework”}
get-module -ListAvailable |where {$.name -like “icinga-powershell-plugins”}
