is it possible to get the “running config” of a icinga node (master, satellite)? With a lot of “import” statements it can get tricky to get the the final object that will be composed at the end and used by Icinga.
THX
~ Markus
Hello and welcome,
you can get all configuration with a lot of information when you run icinga2 object list on one of your master servers.
Regards,
Carsten
that is pretty much what I was looking for.
THX!
~ Markus
i know i’m a bit late, but i wanted to add something. icinga2 object list is nice because it shows what is in icinga various configuration directory, but it’s not really what’s on runtime and loaded in memory, i think getting into the icinga console is closer to what you may need.
