kochd
(Daniel Koch)
July 28, 2020, 12:26pm
1
I need to pass an array to a powershell check. powershell is mess as this is the recommended implementation:
object CheckCommand "powershell_check_services" {
command = [ "C:\\Windows\\system32\\WindowsPowerShell\\v1.0\\powershell.exe" ]
arguments = {
"-command" = {
value = "$ps_command$"
order = -1
"-services" = {
value = "$services$"
repeat_key = false
required = true
";exit" = {
value = "$$LastExitCode"
(not kidding)
check_services.ps1 expects an array (powershell style: “-services foo, bar, batz”)
You can not do “-service foo -service batz” with powershell.
I worked around this by assigning vars.services like this:
vars.services = ["MSExchangeADTopology", "MSExchangeDagMgmt"].join(", ")
Basically as a string - of course this breaks every functionality of having arrays like adding elements, etc.
To proper solve this i would have to call a function on a macro like
$services$.join(", ")
which does not work. Anybody has a good idea for this?
To me it’s the right way to go, just let your service definition build up your needs, i tend to prefer to let CheckCommands being simple and easy to read and have much more flexibles services definitions by abusing macros/functions/DSL to put all the smartness in one place
If you however need more flexibility to process your service array, you can go for something like this :
vars.services = globals.myfunction(["MSExchangeADTopology", "MSExchangeDagMgmt"])
globals.myfunction= function(arr) {
[do whatever preprocessing you want to arr]
return arr.join(", ")
I guess you could also do something like this (didn’t test) :
"-services" = {
value = globals.myfunction($services$)
repeat_key = false
required = true
This can come handy :
https://icinga.com/docs/icinga2/latest/doc/08-advanced-topics/#register-and-use-global-functions
kochd
(Daniel Koch)
July 29, 2020, 10:22am
3
The main problem is that i have to store the services as string at all. It would we be nice if you could just convert them when actually needed as a string.
Your 2nd example would have worked for me but sadly is not allowed as well.
Jul 29 12:16:06 srv-icinga2 safe-reload[19615]: [2020-07-29 12:16:06 +0200] information/cli: Loading configuration file(s).
Jul 29 12:16:06 srv-icinga2 safe-reload[19615]: [2020-07-29 12:16:06 +0200] critical/config: Error: syntax error, unexpected $undefined, expecting ')'
Jul 29 12:16:06 srv-icinga2 safe-reload[19615]: Location: in /etc/icinga2/zones.d/global-templates/commands.conf: 81:26-81:26
Jul 29 12:16:06 srv-icinga2 safe-reload[19615]: /etc/icinga2/zones.d/global-templates/commands.conf(79): }
Jul 29 12:16:06 srv-icinga2 safe-reload[19615]: /etc/icinga2/zones.d/global-templates/commands.conf(80): "-services" = {
Jul 29 12:16:06 srv-icinga2 safe-reload[19615]: /etc/icinga2/zones.d/global-templates/commands.conf(81): value = globals.join($services$)
It’s unexpected, let’s try something else :
"-services" = {
value = {{ return service.vars.services.join(", ") }}
repeat_key = false
required = true
kochd
(Daniel Koch)
July 30, 2020, 7:00am
5
This sadly fails on agent side:
Icinga2 reloads but this is the check output:
Error: Argument is not a callable object.
Location: in /etc/icinga2/zones.d/global-templates/commands.conf: 82:23-82:54
/etc/icinga2/zones.d/global-templates/commands.conf(81): #value = "$services$"
/etc/icinga2/zones.d/global-templates/commands.conf(82): value = {{ return service.vars.services.join(", ") }}
/etc/icinga2/zones.d/global-templates/commands.conf(83): repeat_key = false
/etc/icinga2/zones.d/global-templates/commands.conf(84): required = true
It’s weird, i have a similar configuration in production (for 2.10.5), but for a linux satellite.
I’m using something like this an arguments dict which is running fine :
"-D" = {
required = true
value = {{ Json.encode(host.vars.data["XXX"]["XXX"] + service.vars.XXX) }}
Given your CheckCommand configuration, it seems you are using a windows icinga agent, we may have a problem if functionnality is different, i’d prefer to ping icinga team to confirm it.
Maybe there is a real issue here @theFeu ?
Al2Klimov
(Grandmaster)
July 30, 2020, 1:40pm
7
Hello @kochd !
Have you tried to convert array -> string like this:
==> prefix1/etc/icinga2/zones.d/master/commands.conf <==
object CheckCommand "lolcat" {
command = [ "whatever" ]
arguments = {
"it" = "$takes$"
vars.takes = {{ macro("$takes_arr$").join(", ") }}
==> prefix1/etc/icinga2/zones.d/master/hosts.conf <==
object Host "master" {
check_command = "lolcat"
vars.takes_arr = [ 1, 2, 3 ]
[2020-07-30 15:33:01 +0200] warning/PluginCheckTask: Check command for object 'master' (PID: 29866, arguments: 'whatever' 'it' '1, 2, 3') terminated with exit code 128, output: execvpe(whatever) failed: No such file or directory
