Hello All,
Im a bit confused,
I update the Powershell-Framework from 1.8 to 1.10.1 and got the follwing issue on some checks
I used the versions
- icinga-powershell-1.10.1
- icinga-powershell-hyperv-1.2.0
- icinga-powershell-plugins-1.10.1
- icinga-service-v1.2.0
This configuration with the update is installed on 3 Nodes and one of them is running fine
run it on Powershell:
PS C:\Program Files\WindowsPowerShell\Modules> Invoke-IcingaCheckDiskHealth
Exception calling "Add" with "2" argument(s): "Item has already been added. Key in dictionary: '26' Key being added:
'26'"
At C:\Program
Files\WindowsPowerShell\Modules\icinga-powershell-plugins\compiled\icinga-powershell-plugins.ifw_compilation.psm1:6458
char:9
+ $PhysicalDiskData.Add($MSFTDiskId, $DiskInfo);
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : ArgumentException
