I use the command, check_command disk and use multi partitions chooses.
The Plugin output, i got is not well formatted, i mean no return to line by partition.
Anyone, have ideas, how to do ?
Best regards,
Moustapha Kourouma
Best regards,
Moustapha Kourouma
Hello @Moustapha!
Please report problems with the monitoring plugins themselves to their maintainer.
Best,
AK
Thank you, i did it !
Best regards,
Moustapha Kourouma
