Not sure this is the right place for this but I want to know if there is any way to force the check source for one specific host to be always the same.
Use case:
We have different zones, some of them with more than one satellite/worker/endpoint. There are some network appliances that don’t allow more than one IP for snmp access and we want that all the time those hosts to be checked by same endpoint.
Is this possible?
IcingaWeb 2.6.3
Icinga r2.11.0-1
