We need to force close alert - irrespective of the status of the problem.
This is required as our customer wants if a ticket is closed without closing the problem a new ticket has to be generated.
So to do that we need to have a API call from ticketing system to close the event in icinga. And in next sampling cycle icinga will re-evaluate and will create a new alert - which will create a new ticket
So is there a way to close a event based on ServiceName!Hostname combination irrespective of the status of the actual problem
Interesting thought. Lets say CPU Monitoring is an active check. It checks at an interval with ServiceName = CPU-Monitoring On Server XYZ
Now when a alert fire and CPU-Monitoring Service Ticket is Raised for XYZ.
ServiceNow Identify the Alert as MessageKey CPU-Monitoring!XYZ
So if Someone Closes the ticket we trigger a script sending a PassiveCheck Result to be OK for ServiceName = CPU-Monitoring and Server XYZ
Passive Check Result Freshness will not make the CPU-Monitoring Service Unknown as the active check is working as expected and will keep the Service Working.
