Hi folks…
Just curious, what are you using a huge dashboard on a TV if anyone is using something like that…
Hi folks…
The businessprocess module has a full screen view for that.
Also the toplevelview has been updated to use icingadb
In the past I used GitHub - mocdaniel/dashing-icinga2: Dashing dashboard for Icinga 2 using the REST API
You can also use &showFullscreen for dashboards you created in IcingaWeb2 (or ?showFullscreen if those dashboards don’t have any filters in the URL)
As IcingaWeb2 requires a login, which can be difficult on a TV, you can setup the “kiosk” mode: Advanced Topics - Icinga Web
We use an Icingaweb2 dashboard in kiosk mode for our 24x7 videowall. Works fine.
Hi
For info we use external-auth (our local AD) for everything else.
We made it like this:
<IfModule mod_authz_core.c>
# Apache 2.4
SetEnvIf Remote_Addr "^10\.40\.32\.[0-9]{1,3}" REMOTE_USER=dashboard
<RequireAll>
Require ip 10.40.32.187
</RequireAll>
</IfModule>`
Is a bit of a hassle, but we only needed two dashboards at our place, so that was ok for us.
