Is it possible to filter based on the ‘since’ attribute for hosts and services? - e.g. I’d like to list all services that have been CRITICAL for at least a week.
Is this possible with icingaweb2? If not, is there an alternative method you’d suggest?
Thanks!
Will.
@Pooh I didn’t assume programmatic access. If you’re generating a link to icingaweb2 (e.g. /monitoring/list/services?service_last_state_change>2022-01-28%2011%3A30%3A00&modifyFilter=1) it should be easy enough to generate the proper date string dynamically relative to when it is requested and put it in the request’s query string.
