Hello
Can I assign 2 or 3 host groups to the one host when importing with fileshipper?
groups = [ “Windows”, “Backup” ]
Thx
Hello
Thx
Hello and welcome,
you can assign as much groups to a host as you want. Either the information comes from a file used by fileshipper or you create rules to add more groups during the sync job, even if the groups are not in your source file.
Regards,
Carsten
Thank you very much for answer
but I still can’t get any further.
Thx
Hello @monitorinjunkie
I don’t understand what exactly you are trying to achieve here.
Maybe a little more information would help?
Greetings,
Feu
Hi
I keep getting host lists with lots of servers.
Each host got several (2-3) host groups
And here I fail.
How can I do this with a Fileshpper import?
I need an example or link
Thx
Hello
Did you find a solution? I’ve the same problem. I’d like to assign a host to a Host Group via MySQL Import and Sync Rule.
Cheers
Heinz
@heige Can you show an example of the list?
One host and one group per line or all groups with one host per line?
Hello tqnsls,
Hello heige,
I have not dealt with it any more.
Too much time for a couple of host
I have only entered manually.
Sorry
Hello
Sorry the late answer. At this point in time I didn’t know about the “Modifiers” for the imports. Now I import a csv list and converting it while import to an array. The sync rule assign this array to the host.
Cheers
Heige
