Know someone how should be it integrated in filebeat.yml ? or is not needed to be configured in filebeat.yml ?
Any information can be very useful for me .
I would start simple by configuring the log path at first glance and see what filebeat does. Later on, add specific filter variables and so on. Reply with your progress to let others catch up with this topic too
I succeed to forward the mongodb logs using the mongodb module for filebeat. Below is the configuration that I have configured on filebeat.yml :
###################### Filebeat Configuration Example #########################*
# This file is an example configuration file highlighting only the most common*
# options. The filebeat.reference.yml file from the same directory contains all the*
# supported options with more comments. You can use it as a reference.*
# You can find the full configuration reference here:*
# https://www.elastic.co/guide/en/beats/filebeat/index.html*
# For more available modules and options, please see the filebeat.reference.yml sample*
# configuration file.*
#=========================== Filebeat inputs =============================*
filebeat.inputs:*
# Each - is an input. Most options can be set at the input level, so*
# you can use different inputs for various configurations.*
# Below are the input specific configurations.*
#- type: log*
# Change to true to enable this input configuration.*
# enabled: false*
# Paths that should be crawled and fetched. Glob based paths.*
# paths:*
# - /opt/log/*.log*
#- c:\programdata\elasticsearch\logs\**
# Exclude lines. A list of regular expressions to match. It drops the lines that are*
# matching any regular expression from the list.*
#exclude_lines: ['^DBG']*
# Include lines. A list of regular expressions to match. It exports the lines that are*
#include_lines: ['^ERR', '^WARN']*
# Exclude files. A list of regular expressions to match. Filebeat drops the files that*
# are matching any regular expression from the list. By default, no files are dropped.*
#exclude_files: ['.gz$']*
# Optional additional fields. These fields can be freely picked*
# to add additional information to the crawled log files for filtering*
# fields:*
# level: debug*
# review: 1*
### Multiline options*
# Multiline can be used for log messages spanning multiple lines. This is common*
# for Java Stack Traces or C-Line Continuation*
# The regexp Pattern that has to be matched. The example pattern matches all lines starting with [*
#multiline.pattern: ^\[*
# Defines if the pattern set under pattern should be negated or not. Default is false.*
#multiline.negate: false*
# Match can be set to "after" or "before". It is used to define if lines should be append to a pattern*
# that was (not) matched before or after or as long as a pattern is not matched based on negate.*
# Note: After is the equivalent to previous and before is the equivalent to to next in Logstash*
#multiline.match: after*
#============================= Filebeat modules ===============================*
filebeat.config.modules:*
# Glob pattern for configuration loading*
path: ${path.config}/modules.d/*.yml*
# Set to true to enable config reloading*
reload.enabled: true*
# Period on which files under path should be checked for changes*
#reload.period: 10s*
filebeat.modules:*
#------------------------------- Mongodb Module -------------------------------*
- module: mongodb*
# Logs*
log:*
enabled: true*
# Set custom paths for the log files. If left empty,*
# Filebeat will choose the paths depending on your OS.*
#var.paths:*
# Input configuration (advanced). Any input configuration option*
# can be added under this section.*
#input:*
#==================== Elasticsearch template setting ==========================*
setup.template.settings:*
index.number_of_shards: 3*
#index.codec: best_compression*
#_source.enabled: false*
#================================ General =====================================*
# The name of the shipper that publishes the network data. It can be used to group*
# all the transactions sent by a single shipper in the web interface.*
# The tags of the shipper are included in their own field with each*
# transaction published.*
tags: ["filebeat"]*
# Optional fields that you can specify to add additional information to the*
# output.*
fields:*
type: mongobackup*
# env: staging*
#============================== Dashboards =====================================*
# These settings control loading the sample dashboards to the Kibana index. Loading*
# the dashboards is disabled by default and can be enabled either by setting the*
# options here or by using the `setup` command.*
#setup.dashboards.enabled: false*
# The URL from where to download the dashboards archive. By default this URL*
# has a value which is computed based on the Beat name and version. For released*
# versions, this URL points to the dashboard archive on the artifacts.elastic.co*
# website.*
#setup.dashboards.url:*
#============================== Kibana =====================================*
# Starting with Beats version 6.0.0, the dashboards are loaded via the Kibana API.*
# This requires a Kibana endpoint configuration.*
setup.kibana:*
# Kibana Host*
# Scheme and port can be left out and will be set to the default (http and 5601)*
# In case you specify and additional path, the scheme is required: http://localhost:5601/path*
# IPv6 addresses should always be defined as: https://[2001:db8::1]:5601*
#host: "localhost:5601"*
# Kibana Space ID*
# ID of the Kibana Space into which the dashboards should be loaded. By default,*
# the Default Space will be used.*
#space.id:*
#============================= Elastic Cloud ==================================*
# These settings simplify using filebeat with the Elastic Cloud (https://cloud.elastic.co/).*
# The cloud.id setting overwrites the `output.elasticsearch.hosts` and*
# `setup.kibana.host` options.*
# You can find the `cloud.id` in the Elastic Cloud web UI.*
#cloud.id:*
# The cloud.auth setting overwrites the `output.elasticsearch.username` and*
# `output.elasticsearch.password` settings. The format is `<user>:<pass>`.*
#cloud.auth:*
#================================ Outputs =====================================*
# Configure what output to use when sending the data collected by the beat.*
#-------------------------- Elasticsearch output ------------------------------*
#output.elasticsearch:*
# Array of hosts to connect to.*
# hosts: ["cormoran.it.pirelli.com:5044"]*
# Optional protocol and basic auth credentials.*
#protocol: "https"*
#username: "elastic"*
#password: "changeme"*
#----------------------------- Logstash output --------------------------------*
output.logstash:*
# The Logstash hosts*
# Optional SSL. By default is off.*
# List of root certificates for HTTPS server verifications*
#ssl.certificate_authorities: ["/etc/pki/root/ca.pem"]*
# Certificate for SSL client authentication*
#ssl.certificate: "/etc/pki/client/cert.pem"*
# Client Certificate Key*
#ssl.key: "/etc/pki/client/cert.key"*
#================================ Processors =====================================*
# Configure processors to enhance or manipulate events generated by the beat.*
processors:*
- add_host_metadata: ~*
- add_cloud_metadata: ~*
#================================ Logging =====================================*
# Sets log level. The default log level is info.*
# Available log levels are: error, warning, info, debug*
#logging.level: debug*
# At debug level, you can selectively enable logging only for some components.*
# To enable all selectors use ["*"]. Examples of other selectors are "beat",*
# "publish", "service".*
#logging.selectors: ["*"]*
#============================== Xpack Monitoring ===============================*
# filebeat can export internal metrics to a central Elasticsearch monitoring*
# cluster. This requires xpack monitoring to be enabled in Elasticsearch. The*
# reporting is disabled by default.*
# Set to true to enable the monitoring reporter.*
#xpack.monitoring.enabled: false*
# Uncomment to send the metrics to Elasticsearch. Most settings from the*
# Elasticsearch output are accepted here as well. Any setting that is not set is*
# automatically inherited from the Elasticsearch output configuration, so if you*
# have the Elasticsearch output configured, you can simply uncomment the*
# following line.*
#xpack.monitoring.elasticsearch:*
#================================= Migration ==================================*
# This allows to enable 6.7 migration aliases*
#migration.6_to_7.enabled: true*
But I still have some “issues” :
2019-06-18T11:45:55.910+0200 ERROR instance/beat.go:802 Exiting: Index management requested but the Elasticsearch output is not configured/enabled .
I don’t know where I should disable this .
Regarding the mongodb module, on his configuration I have modified only the var.paths which a test path .
Have you some suggestions for me related to that error ?
The output is set to logstash, not elasticsearch - so you’re using Logstash for additional filtering in the middle. Your configuration defines that filebeat tries to manage the indexes on its own, without having configured the elasticsearch output.
Look for Elasticsearch template setting and disable that. Just guessing, the filebeat docs or likewise, discuss.elastic.co might provide better help.
